Old 08 Aug 2009, 09:40 pm
slartyblarfast slartyblarfast is offline
Default Re: A/C blowing warm then cold idling & overcharged!!!
Originally Posted by 66CUDA View Post
What's not making sense is that the fan turns on when the pressure gets high and turns off when it lowers it to the correct pressure. To me it seems it could be the switch malfunctioning and not turning the fan on earlier because the switch is telling it to turn off. From my experience when a fan goes bad it either just stops or spins erractically and stops and does not perform the function of cooling down. My fan is cooling down the pressure but it isn't being told to react quicker. Since the switch is easiest I'll do that first and keep ya guys posted....
66CUDA
Pt fans have a 2 speed operation. Low speed works off of engine temp unless it gets too high then high speed kicks in. The high speed runs solid as long the a/c is on.
