Old 09 Aug 2009, 12:46 am
ab1 ab1 is offline
Default Re: Front Ball joint replacement Easy or Hard??
Originally Posted by luvmysxs View Post
since you have 100000 miles on the pt, 3 hours per side definitely not worth just replacing the ball joints since the bushing usually are shot by then. what i did was replaced the complete control arm assy, new bushings, ball joints, control arms, cost was $80 per side with life time warranty, took appox 2 hours to replace both sides. then had the wheels realigned for another $65.
I was going to replace the entire arm but I got everything including new bushings for under 50$. (MOOG Ball joints 25$ for 2 , MOOG horizontal bushing for 7$ for 2 and MOOG vertical bushing 13$ for 2) The passenger side took about 1 hr and 45 mins. even though I had to remove the splash guard and a few other bolts. Got realigned for 74$.
