Old 09 Aug 2009, 09:16 am
CREWZIN CREWZIN is offline
Default Re: Car died, wont start! HELP PLEASE!!!
You can just keep throwing parts at it. A scanner could have narrowed it down for you. You did check the wiring from the Camshaft sensor, right? The Crankshaft sensor is located behind the engine above the oil filter. Check those wires also.
As a forewarning, some owners have replaced the camshaft sensor with an after market part form Auto Zone or other store and still had the original problem. Replacing the sensor from the dealer (yes it does cost more) solved the problem.
