Hi,
We have a 2002 base model that didn't come factory with the fog lamps.
I was able to get a multifunction switch off of ebay (stock turn signal switch with the fog light switch built in), and a set of used fog lights from ebay also....
Anyways....I have all the wiring details....and can walk ya thru it. You can use an aftermarket switch to run them, no need for the stock switch. I can even tell ya how to wire it up so the aftermarket switch will turn on the green dash lite indicating the fogs are on.
Let me know if you need info.....Dalec74@commspeed.net
Dale
