Here's what you do. Tap it on with the dead blow till the threads on the crank bolt engage atleast 4 or 5 turns. Then just use the crank bolt to run it on. Do it every time and never had a problem. The hammer will not get it done plus can cause damage to the thrust bearing. There is no keyway for the crank dampner so it doesn't matter where is is.
