That I did not know, now the trust is there.
Thank you!
I did or tried to do the solenoid test with the scanner last night. Im not sure how that test is supposed to work. I had a code p0755. We cleared the codes, and cycled the key. Cranked it, then I got a p0300 cylinder misfire. Any idea why that happened? Cleared the codes again, and all I have now is the p0755. I think Im going to go ahead and replace the solenoid pack. The scanner we were using, showed the relearn function, so maybe Ill just go that route. Thanks for all your input!
