Originally Posted by chris15
5) Lastly, you have to pry off the center bezel, applying the same practice as the window switches. I have found it's best to work from the bottom edges, up.
Rather then pry out the bezel, you could also grab it by the hole where the window switches were, and carefully pull it out. It should pop out pretty easiliy.
srg
