Old 17 Aug 2009, 10:57 am
YoungCruiserrr's Avatar
YoungCruiserrr YoungCruiserrr is offline
Send a message via AIM to YoungCruiserrr
Default Re: Center Dash Removal
use the search option on the forum, it works great. I suggest taking a flat screw driver and popping the windows switch thing out from the top, then there is a screw and you unscrew that and will be able to pop it out with ease, no scratching it and no breaking clips
EDIT:
here is a link if you got 06+ I'm not sure if your talking about dash, or bezel, but here is another link that helps, I suggest taking out center bezel just to help the process run smoothlyHow do you remove the dash top panel?
2005 Brilliant Black
PT Cruiser Touring Edition
34,000 Miles.
