Re: Custom Wheels and tires
Originally Posted by Chromenut
On the strut thingy, the distance changes between models of struts. The pan, or spring seat, is even different shape between some of them. I just kind of threw that out there as a generalization.
I dunno. If they're not the same, they should be. Let's say you ordered new struts from Company "A" to replace the ones on your car that are from Company "B". Say you've got aftermarket wheels and slightly larger aftermarket tires like you do. How pissed would you be if you went to put those struts on and they wouldn't fit because the spring seat is lower than it should be? I'm not saying you're wrong, I'm just saying it would be awfully stupid for companies to mess with that distance on struts made for the same model car.
On the last one, yes, you said the same thing I said, only you said it differently. The backside spacing is from the back of the rim to the mounting surface. And I said the same thing, backspacing and offset are different. You got dat right man!!
My mistake! I misread your post.
1973 Barracuda
340/auto
Modifications: Too many.
2002 PT Cruiser
N/A 2.4L/5-speed
1989 Caprice Wagon
307/auto
