Re: What wheels will fit an 01 PT?
You would have to look for a Neon or PT. The other vehicle stock wheels could most likely have a different hub size.
For example, if you find VW Jetta steel wheels with the 5x100 lug, the bore sixe is bigger then the PT's. In theory, they will fit, just not perfectly. Also look out for Subaru, Dodge Avenger (I think) and.....
And since you are getting rid of the car....find anything that fits.
2005 Touring Black - Automagic....
H&R Cup Kit | TSW Sakata 18x8 35ET | Nankang NS-II 235/40/18 | SPC front alignment cam - rear shim | OEM Rotors | Akebono Ceramic Pads | Rebuilt Cylinder Head - Safety Valves and Guides | Felpro Head Gasket and upper rebuild kit | Fail-safe 195 degree thermostat | Mopar Waterpump...lol | 3rd radiator fan motor | Gates timing belt kit | WIX filters (oil, transmission) | Mobile 1 5w30 | Mopar ATF4 | Redline Water Wetter | K&N Drop-In
