Re: Installed dual Gauge pillar pod
I see. Which gauges did you wind up using? I was thinking about using the tinted 7-color series. I'm assuming since you said you swapped bulbs, you just went with the standard gauges, right?
That's good info. I can't quite remember what's in the vicinity of my oil filter, but I'm sure it's very similar to what you did. I'm definitely going to have to invest in some ramps or something, though.
Another quick question-- when you buy the pod, does it matter what color the pillar is beneath it? (The stock one) Or does the pod not completely cover the stock pillar? Just cause there's someone with a junked PT on here that I'd like to get the pillar from but I'm not sure if the color matters. (Not sure what they have, either.)
Thanks again man, I appreciate it, and I'll probably consult you a bit more as I go through with this.
2001 PT Turbo - In the process of a major overhaul.. :]
2006 Cobalt SS/SC - Stage 2, 3" Exhaust, Meth and soon to come: Zex 75-shot :]
