Thread: "Wet" Plugs
Old 24 Aug 2009, 06:29 pm
chris15's Avatar
chris15 chris15 is offline
Default Re: "Wet" Plugs
If oil's on your plugs, it typically should be seen on the tips as well.
Have you personally done all the work on your car? Sure it's not just crappy dielectric grease?
Alternatively, have you checked your PCV valve? Oil in your combustion chambers could be the result of a plugged PCV valve causing an increase in crankcase pressure, pushing oil past your rings.. If your PCV valve is functioning properly, you could have one or more worn piston rings or could be your valves.. best thing to do is a compression check to rule either of those out.
2001 PT Turbo - In the process of a major overhaul.. :]
2006 Cobalt SS/SC - Stage 2, 3" Exhaust, Meth and soon to come: Zex 75-shot :]
