Re: HID Kits for sale
off the subject....
I see you have an R/T Dakota. I have an identical 2002. I dont use it much, hence the 42k miles on it. It mostly sits around. I recently replaced a u-joint and the rear transmission seal. Just wondering if you had the same issue....
2005 Touring Black - Automagic....
H&R Cup Kit | TSW Sakata 18x8 35ET | Nankang NS-II 235/40/18 | SPC front alignment cam - rear shim | OEM Rotors | Akebono Ceramic Pads | Rebuilt Cylinder Head - Safety Valves and Guides | Felpro Head Gasket and upper rebuild kit | Fail-safe 195 degree thermostat | Mopar Waterpump...lol | 3rd radiator fan motor | Gates timing belt kit | WIX filters (oil, transmission) | Mobile 1 5w30 | Mopar ATF4 | Redline Water Wetter | K&N Drop-In
