Re: Aftermarket headunit gets constant power. Please help!
i had the same problem with my 06 cruiser, i could not get it to turn on, after futher investigation i found that there was no ignition wire coming off of the harness, the wiring harness does not have a ignition wire. (red wire) so you will have to find a ignition wire some were in your car. luckly ive already did this and i no where one is lol.
THIS is how you solve it with out spending money.
pull your carpet away from the lower part of your center consle. located the cigerette lighter power wire/ground wire. its going to be in a black mesh sheilding.
theres 2 wires so make sure you do not cut through the ground. The pink wire is what you need to splice into. splice it and run a wire up to the red wire on your cd player. make sure you re connect the cigerette lighter wire and properly wrap it so you have no exposed copper.
once you do that the cd player should turn on and off like normal.
hope this helps
Enkei WDM Rims, Falken Ze-19 Tires, Flowmaster Super 44, K&N Cold Air Intake, AirRaid Throttle Body, XEON Head Lights, Crunch 1100Watt Sub Amp Running Two 12' 1200watt Square Hifonics Brutus Subwoofers, 900Watt Crunch Highs Amp Running 12 Power Acustik Speakers. Pioneer head unit
