Old 29 Aug 2009, 11:26 pm
Default Re: Newbie to site...
Originally Posted by Hooligan View Post
You can use stock plugs but get any wires other than stock, stock wires are known to break down quickly. As long as you are doing the wires, do the plugs as well, use the "Sticky" posted in the performance section. Remember this is a sticky for a non-turbo so your car may be a different set up. You will NOT have a EGR valve. Plugs (if I remember right) are to be .032 to .035 gap.
Unless you are having a problem with the tranny, don't use a additive.
Agree. Be sure where you take it has a flushing machine and be sure they use ATF + 4 only.
