  #16 (permalink)
Old 02 Sep 2009, 09:13 am
CYCLONE_06 CYCLONE_06 is offline
Send a message via AIM to CYCLONE_06 Send a message via Yahoo to CYCLONE_06
Default Re: Installed dual Gauge pillar pod
Originally Posted by slipstream74 View Post
Here's my install.
Looks good for sure. Glad I can help you guys out. The vac line on the throttle body is much safer to use than the brake booster line. And that sandwhich adapter really makes life simple. The hardest part was running the tubes / wires, etc.
Slipstream, might I suggest finding some covering for your boost tube... it will help protect it from the heat of the manifold under the hood. I ran mine through a rubber tube I had laying in the garage and it blends in like it came from the factory.
Where does your oil pressure usually carry around 55 to 60 mph ?
~CYCLONE_06
