Re: Undersized Front Woofers - how to retro fit???
Hi Duster,
The problem seems to be the door hole is too large for the speakers (at least it is VERY close). I am concerned that if I attempt to drill new holes, they will be so close to the edge of the door hole that they will basically end up making a slot, not a hole. Is this a normal issue? Again, Crutchfield showed these speakers as "fit", but the radius of the hole pattern on the factory speaker is longer than the radius of the hole pattern on the new speakers. The radius of the mounting hole pattern on the new speakers is only slightly longer than the radius of the hole in the door.
