Old 16 Sep 2009, 11:13 pm
KLCruiser KLCruiser is offline
Default Re: curious about BOOST!
Go to PTCrew and read up. And get a wideband. 18psi spike settling around 15psi is said to be the max the fuel sytem can handle with s1 pcm. I had a s2 wga in my car for about a week and quickly realized the wideband was a must. I could step on it going 30mph in second and full on light up the tires!
You are also going to want the s1 pcm or you will be throwing codes!
2004 GT, 5spd, Stage1, K&N FIPK, Magnaflow 2.5" Catback, 3" O2, 3" Needswings Catless DP, Mopar BOV, NGK Iridiums, Mopar Wires, Aeroforce Interceptor w/wideband kit, Vibrant Catch Can, Prothane Inserts, AMX1397 upper and lower pipes, Plastic Intake, Hurst STS, S2 WGA, Factory Sub and now Alky Injected!
