Old 17 Sep 2009, 07:14 pm
SteveLivingStrong SteveLivingStrong is offline
Default Dynamat Speaker Kit & moisture barrier
This is kind of combo question. I recently purchased a new head unit and new front speakers (components) and rear speakers for my 05 GT. Got them in and components are a little bright for some audio sources even with 7 band equalizer control. I may try to use the -3 db on the crossovers to cut some, but as I saw somewhere on the forum, the PT seems to be eating mid-bass. Anyway, Crutchfield included two speaker kits for free with the order. I did not put the kits in initially, but I am thinking of trying them since they were free. My question is with the moisture barrier/water dam. I need to pull it back and clean the metal where the dynamat will be applied. So, I have three questions:
1) What did you recommend using to clean the adhesive?
2) What adhesive is recommended to reapply on top of the dynamat to re-secure the moisture barrier/water dam?
3) For those that have installed the speaker kit, is the improvement worth the trouble of step 1 and 2?
Also to combat the bass problem, I purchased a new mopar subwoofer off of Ebay and will be adding, so hopefully that will make fill in some as well. Thanks in advance for any suggestions!
