Re: wastegate & boost controler? wasteband?
This is exactly where I am at in the mod process. Just ordered the Aeroforce Interceptor which reads multiple parameters including afr when you add their wideband kit. This way I can watch boost and afr at the same time on one gauge! Kind of pricey though, gauge is $240, wideband kit another $195ish. But not a whole lot different than buying separate boost and afr gauges I guess. Plus you can do a bunch of other stuff, like read engine codes, 0-60 times etc.
 2004 GT, 5spd, Stage1, K&N FIPK, Magnaflow 2.5" Catback, 3" O2, 3" Needswings Catless DP, Mopar BOV, NGK Iridiums, Mopar Wires, Aeroforce Interceptor w/wideband kit, Vibrant Catch Can, Prothane Inserts, AMX1397 upper and lower pipes, Plastic Intake, Hurst STS, S2 WGA, Factory Sub and now Alky Injected!
