Re: knock sound in front pass wheel well, 01 pt cruiser
Half shaft, strut is loose, or maybe front sway bar. You can get under the car and look at the bushings surrounding the sway bar to see if they are worn. You can jack the car up and grab hold of that tire and shake it to see if your strut assembly is loose, or jack the whole front up, with engine in neutral, turn the wheel in circles while pulling either left or right to see if you have play in the half shaft. All three you need a jack or jack stand or ramps.
If you need photos of what I'm talking about, let me know, I've got plenty....
