Old 19 Sep 2009, 05:04 am
Kell Kell is offline
Default Auto-dimming rearview mirror & '06+ PT Domelight?
I recently picked up a Gentex 221 dimming mirror from ebay and wired it into my '06 PT.
I did run across one slight problem, however. Tapping into the positive wire on the dome light (to signal the mirror to turn on the led map lights when the doors are open/dome light is on) seems to have had a reverse effect from what I expected.
With the wire plugged into the mirror, the dome light comes on when the doors are open fine, but the mirror's map lights do not. Once the door is closed, the map lights turn on full time.
-edit-
It looks like the PT has +12v on both lines when the door is open, vs. the 0v when the door is open with other manufacturers.
Type B. Most full-size Ford and some Chrysler vehicles use a circuit that has two wires at the door jam switch. When the door is closed, there is +12 volts on one wire but not the other. When the door is open, there is +12 volts on both wires.
