Re: Getting Started
Originally Posted by KLCruiser
Probably the Air box mod which will cost you a K&N drop in filter. Not sure on cost, $25 maybe? Search it out and you will find instructions.
New plugs and wires are a good idea as the factory wires are crap.
Next Stage 1 which gives you 5hp and 15ftlbs of torque on the '06. $600, but is the building block for many more mods. Basically all that is invloved here is swapping out the pcm.
Beyond that you will want a boost gauge, maybe wideband. Bigger exhaust, boost controllers, stiffer waste gate actuators, the posibilities are endless!!!
Btw are you auto trans or 5spd?
Go and check out PTCrew.com.
Agree. And gap the plugs no wider than 0.040, and do NOT use platinum - either copper or irridium only in a turbo.
Easiest gain is to put 2-3 PSI more in your tires - seriously.
