Re: Dynamat Speaker Kit & moisture barrier
Well, I was under the impression that when you peel the moisture barrier back that the adhesive would stick to the metal rather than the barrier. If the adhesive stays with the barrier, then you're right, I won't need to purchase any. I think when I read the instructions it said to clean the metal before applying the dynamat and I guess in my mind that meant the adhesive. So, when you pull the moisture barrier back, does the bulk of the adhesive seem to stay on the barrier itself? I guess I could try it first, but I was just trying to make sure I had the necessary pieces and material before I got started.
