Re: 01 radio lighting comes and goes
2001 Limited - Same problem. Seems to be in the headlight / turn signal switch. Power or ground, haven't figured which. If I press on the wiring harness for the headlight switch or lift up on the wheel the radio display and horn work again. Looks like the switch depends on being grounded thru the steering wheel tilt mechanism. Over time this connection has gotten worn and very dirty / rusty. I need to add a ground wire from the switch to solid ground to check if this is the problem. Or I need to somehow clean tilt mechanism. Will updated you when I fix the problem.
