Old 23 Sep 2009, 06:45 pm
CREWZIN CREWZIN is offline
Default Re: Power Outlets Died
Found this on PT Do-It-Yourself.net:
Recheck fuse #19 (20amp) in the PDC. If it's ok and both power outlets are dead it's most likely an issue with the circuit wiring. It is not likely to be the ignition switch since the front power outlet is always hot regardless of ignition switch position and the rear power outlet is controlled by the ignition switch.
