Re: Any one put factory Fogs on car that did not have them???
If you use the headlight or running light wire to energize the coil of a relay, it won't fry the wiring - a relay coil doesn't draw much - I did it for my LED washer lights - got the relays at radio shack.
You could still put a switch in series with the coil wire - the fogs could only come when headlights or running lights are on, but you could turn them off.
