Old 28 Sep 2009, 02:34 pm
cjb15 cjb15 is offline
Default Re: Front Wheel Bearing/Hub Assembly Help
You missed a post on just this subject in the tech section. Essentially, the bearing gets pressed onto the hub and into the hub mount after the old parts are pressed out. You need an arbor press and a bearing spreader to do it.
My gut feel is that you could save some money it you removed the hub and bearing assy and found a shop with a press.
