Thread: Getting Started
Old 29 Sep 2009, 11:56 am
nevinsrt's Avatar
nevinsrt nevinsrt is offline
Default Re: Getting Started
one thing to do also is install a boost gauge then boost leak test.
buy a bag of zip ties and ziptie all you vacume lines
go to home depo or lowes and buy a 2" plumming cap, get a valve stem from autozone and put it in the center of the cap, remove the intake and place on the turbo inlet and fill the system with air. take a bottle of soap and water and spray on various vac lines and look for air bubbles.
a few places that will leak air is the factory PCV valve, go to the junk yard and pull a brake booster off a honda or nissan, or go to bwoodypreformance.com and buy one from the SRT-4, insert it on the vacume line between the intake manifold and PCV valve.
another common place you will see a leak is a vacume line on the turbo to airbox (TTAB) pipe, remove that line and cap both ends.
Nevin.
03 SRT-4 — 132k mi ported stocker and lots of other stuff
68 Mustang Coupe — project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. — last dyno 245hp/283tq @ 15psi — OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
