  #12 (permalink)
Old 30 Sep 2009, 12:17 pm
Default Re: Stop Turbo from turning?
Originally Posted by Spark View Post
Thanks. Shouldn't the Turbo last more than a few minutes without oil flow. I would think it would take a couple hundred miles of driving before it destructs.
It's getting oil. I removed the drain line hose at the bottom and placed the end of the line in an oil can. Started the motor. The oil is making it through the Turbo. How much oil flow does it require? Example: A steady oil flow as if you open a drain plug. A fast drip or a slow drip.
A few minutes, at the temps a turbo gets, I would think is enough to cook it.
If you're getting oil, then I don't know why it died.
You might try PTCrew.Com - more turbo gurus there...
