Originally Posted by bobdole369
I think PT Cuda means drop it to 3rd prior to stomping it. Yup the tranny will do it for you, but whilst stomping it, your RPM and torque ARE going up, and as OD is the weakest clutch pack - it can take the least torque. No idea if it actually helps anything, but I used to do that in my camaro just because I had that thing apart and I know exactly why some folks say to do that.
There are less clutches in OD than the other gears. Having 100 ft lbs of torque / 2 clutches is worse on them than having 100 ft lbs of torque / 3 clutches. Add that the trans is disengaging 4th and slamming it into 3rd at the same time - and there is a potential issue.
Totally conceivable that you could be boosting while the trans hasn't finished downshifting. Torque comes up quick as soon as boost starts up. Here is where turbo lag is your friend.
ding ding! Dude you got it.. I've seen so many people tear the 41te to shreds that its the first thing I tell people, the boost will happen before the computer can swap the cogs around in the trans = burning up the clutches..
It was the main reason I hunted for months for a Getrag PT..
The silver 03 GT is gone, but a Solstice has arrived. There are three more PT's to play with though
My personal thanks to veteran and novice crewbies that have offered information and how-to's they have been instrumental in taking LiquidPT from modded car to stock to live a more quiet and sedate life.
