Re: Coolant Leak
crewzin:
I'm going to look again very carefully. Have eliminated the two radiator hoses, heater hoses, radiator cap and thermostat housing and the actual radiator.
Coolant comes from passsenger side unto the plastic cover and to the ground from there.
The water pump gasket design looks to me like it would be very hard to leak from there, as the propeller shaft is totally enclosed. Other mfrs' water pump leak from the shaft's seal but, the shaft in this pump is enclosed totally.
Thanks for your response.
I misspoke, the water pump has a shaft that could leak.
