Old 06 Oct 2009, 07:55 pm
ChefTank's Avatar
ChefTank ChefTank is offline
Default Re: Fuel Pressure Regulator
You can run a schrader valve off the 03 fuel rail to an aeromotive fuel pressure regulator and run your own return line to the tank... Total cost $350ish. Make sure you run boost regulated pressure as to not starve the engine... That is hook the fpr to any boost line so when boost increases so does fuel pressure. If it sits at a static value and the demand increases new motor go boom.
Josh
Stock Turbo 300+ ft/lbs wtq
Stage 3 powered PTGT 25psi and lovin it!
Tial Ext Gate FTW!!!
