Thread: error code...
Old 06 Oct 2009, 07:58 pm
superpug666's Avatar
superpug666 superpug666 is offline
Default Re: error code...
Originally Posted by CREWZIN View Post
It's possible for the 02 sensor to get a sniff of bad gas or something that would cause it to throw a code and after a certain amount of time after seeing everything is OK, go back to normal and pull the signal that goes to the computer. I wouldn't worry about it unless it comes back.
Same thing happens when the code comes up which means the gas cap wasn't tightened properly. When is is tightened, the light will go off after awhile.
with that age comment you made, and your wisdom, crewzin you're like our Yoda ihihihihihiih
I drive an hybrid, it burns both gas and rubber!!!!!
To hell with all religions!
Yes my baby is stock, for now!
