Old 07 Oct 2009, 09:34 pm
Matt42's Avatar
Matt42 Matt42 is offline
Default Re: New brakes are noisy
Originally Posted by PurplePTGirl View Post
I just had my front brakes redone. The rotors were turned and resurfaced, and I installed new ceramic pads. When I brake, I hear this sort of whine that sounds like a motor spinning down (a whirring sound).
Is this normal with ceramic pads?
When you returnj to the place that did the work, ask them how they "bedded" the brakes. I have read that ceramic brakes are more fussy about bedding. I can't say one way or t'other, since I am using my first set of ceramics (and I don't like them.)
Bedding brakes requires making several abrupt stops from about 60 MPH to about 10 MPH, but not to a full stop. Some ceramic brake instructions call for four repeated stops.
I can truthfully say that brakes take a while to break in, and that the bedding really helps.
Does the whine happen all the time? Does it only whine when you are using the brakes? Does the whine go away when you give the brakes more pressure? (That can indicate that the pads are vibrating and might benefit from pad adhesive that sticks them to the caliper.) Was the previous set of brakes ceramic?
1996 Dodge diesel 4X4, 2001 PT Cruiser Touring with rear disc brakes, 2004 PT Cruiser Base 5 speed, 2007 Chrysler T&C Touring
