Well I just had mine done at a place called Stereo Advantage here in Indianapolis they only charged me $60.00. They cut the wires to the stalk and installed a switch between the rear window wiper and the traction control and to top it off they made the indicator light the same color as the car
If I turn the key off the lights go off so in case I forget and leave them on they won't drain the battery and they come on without the head or amber lights.
I'm happy.
The last wiring job I did did not go to well
so I did not have the nerve to do it myself this time!
Everything is working now, next thing on the list is the timing belt, coolant flush and pressure check, new plugs and wires.
Yeah I'm putting a small fortune into this thing but when its all the wheels you got and use on a daily basis they need to work.
