Re: Will not turn over
Sounds like your computer took a dump. To test if the timing belt is still in one piece, take off the Camshaft Position sensor and turn over the engine. Watch the space where the sensor came off and see if it's turning. That's the end of one of the cams and if the belt is good it will be turning and of course if it's not turning while your cranking, the belt has broken.
That's a little thing I picked up from my mechanic.
