  #11 (permalink)
Old 10 Oct 2009, 05:44 pm
edsidders edsidders is offline
Default Re: 01 radio lighting comes and goes
Originally Posted by Eric01 View Post
2001 Limited - Same problem. Seems to be in the headlight / turn signal switch. Power or ground, haven't figured which. If I press on the wiring harness for the headlight switch or lift up on the wheel the radio display and horn work again. Looks like the switch depends on being grounded thru the steering wheel tilt mechanism. Over time this connection has gotten worn and very dirty / rusty. I need to add a ground wire from the switch to solid ground to check if this is the problem. Or I need to somehow clean tilt mechanism. Will updated you when I fix the problem.
I have been tied up doing some consultant work and have not had much time to play with toys , have you had any luck with the problem solving??
This Black Thing Keeps Chasing Me
YES ! That is a Ron Paul for President Sticker..
Growing OLD is Natural - Growing UP is Optional It's NEVER too late to have a Happy Childhood
Ed Sidders , Lake-O The-Pines , Northeast Texas
