Old 11 Oct 2009, 03:38 am
oldcoach's Avatar
oldcoach oldcoach is offline
Default Re: Fog Light Wiring
Originally Posted by h100250 View Post
I'm sorry I should of included the fact that they put a amp meter on the switch and it was only drawing 460ma which is not even 1 amp and to his understanding there is already a relay used from the wiring diagram he had.
You just may want to look at your amp reading! The stock lamps for the fog lights are 9006 blubs and should be around 50 watts. So 100 watts and 12volts should give you an amp reading of aound 8 amps.
Also take a closer look at the wiring for the lights at the MFS. The relay that is part of the MFS is used to turn off the fog lights when the High beam lights are turned on.
02' Black Woodie Limited Edition Drop in K&N Air Filter w/air box mod. 06 tail lights, Limo tint all around, orange LED interior, Mopar 8 inch sub, Stull side pipes. Silver stars upfront, a little chrome
