Re: Subwoofers causing door and dash speaker distortion(?)
Ok well that ground may not be the best ground. thats most likely your issue
i have my sub amp and highs amp grounded to the bolt NEXT to the drop down bolt for your spare tire, and i have no feedback.
the power wire may not be an issue but you maybe limiting your self with power due to the gauge of the wire your using.
for example, i have a One 4gauge power wire running to a Fuse box and from there splits into 2 wires going to my amps.
what you said about the dimming of the lights is a problem that would be fixed by a cap.
If you didnt no or for the people reading this that do not know, caps are used to store extra voltage, that extra voltage is used when you get a spike in power (ie when you subs hit), thus if you do not have a cap, and you getting dimming headlights and gauge lights you would have to purchase one to keep that from happening.
i personally do not have a cap in my car.
Enkei WDM Rims, Falken Ze-19 Tires, Flowmaster Super 44, K&N Cold Air Intake, AirRaid Throttle Body, XEON Head Lights, Crunch 1100Watt Sub Amp Running Two 12' 1200watt Square Hifonics Brutus Subwoofers, 900Watt Crunch Highs Amp Running 12 Power Acustik Speakers. Pioneer head unit
