Old 14 Oct 2009, 12:07 pm
Default Re: 04 PT Cruiser LE
Welcome.
P0304 is cyl 4 misfire. New wires should cure that, but it is usually good to do plugs & wires at the same time.
Your "multifunction switch" crapped out. It's the left "arm" on the steering wheel. You buy the whole arm, and it's easy to replace with a small torqx driver. When you order be sure to get a MF switch with the fogs...they come without, too.
