Originally Posted by oldcoach
Trying to get this nailed down, when you move the wheel up and down and the radio light goes out, is it the horn will now not work or it honks when the wheel is moved up and down.
Also when the radio light turns off is the odometer light also out?
(1)The two items seem to be separate, times the horn won't blow and the radio display lights are on and vice versa as well as both problems or no problems at the same time..I don't have a schematic but I'm guessing that the horn ckt.relay is energized when the horn button in the steering col. is switched to ground.The radio display also works thru the dash dimmer rheostat.. I'm beginning to wonder if both of these leads connect together at a ground point that moves when the wheel is tilted and that connection has burnt and the slag is causing a int. connection.
(2)The odometer light stays on
Leaving for r/c boat races @ Houston tomorrow ,open water Fri ,3 heats Sat,2 heats Sun, be back middle of next week and should have time to dig into it..
This Black Thing Keeps Chasing Me
YES ! That is a Ron Paul for President Sticker..
Growing OLD is Natural
- Growing UP is Optional
It's NEVER too late to have a Happy Childhood
Ed Sidders , Lake-O The-Pines , Northeast Texas
