  #16 (permalink)
Old 15 Oct 2009, 11:14 am
nevinsrt's Avatar
nevinsrt nevinsrt is offline
Default Re: PT GT Floats! Well, kinda...
Originally Posted by sknight88 View Post
So I managed to have the tires lose there grip on a super slimy boat ramp. Car was in park. Hit the water, and FLOATED away. Yes, it floated. Made it about 100 feet away from the ramps edge and sat there looking at me for over 5 minutes! Then finally the door seals could take no more, she let out a big gasp of air and sunk to the bottom! PT GT RIP 2004-2009
Ooooooooooo!!!!! *speachless*
you know you did make that sound funny in a way...
Nevin.
03 SRT-4 — 132k mi ported stocker and lots of other stuff
68 Mustang Coupe — project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. — last dyno 245hp/283tq @ 15psi — OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
