Re: engine cranks but wont start
Bad Coil ,Did you check the spark at the plugs, closed gap on plugs ,Try a spare key, chip may be bad...Did you do the key off key on trick to check for any codes..Check shaft sensor, i would still check the fuel pump fuse....Hell see if it will start in nuetral mabey the switch is bad...
