I know you guys like to see pictures, so do I. The 1st picture is an exterior shot of the transmission tunnel completed. Here you can see more clearly where I cut off the main crossmember in the green circles. The 2nd picture is of the interior after I re-installed the carpet, floor shift console and floor shifter. Don't look like theres a GM trans under there, does it? Still looks like the stock floor. Shortly after that is when I modified the floor shift console and floor shifter. The gas pedal was relocated to the left a little, and the brake pedal was re-positioned to the left as well. Thank you, Tommy.
