Re: Corroded rims causing air to leak.
You've already Googled and found out that many others have the same problem. Contacting Chrysler after the car has been on the street for 9 years will only result in laughter on the other end of the line.
The best thing to do is have the wheel taken apart and sand down the rusty parts (probably all around the whole rim). Coat those parts with some sort of rust inhibitor. That will probably hold your air leak to a bare minimum and then save up for new wheels.
As far as your drive tonight, it's kinda late to do anything now. Check your spare tire to make sure it's filled up. Read your owners manual to find out how to change your tire if needed. Check to see if you have a tow/rescue policy with your insurance. Pick up a can of "Flat Fix" for an emergency, and lastly, keep checking the tire as you go along. Your better off with a few pounds over inflated than under.
