Old 25 Oct 2009, 09:38 pm
chris15's Avatar
chris15 chris15 is offline
Default Re: few turbo questions
The comparison was meant to be made between the N/A and the turbo, not necessarily JUST the GT. I stand corrected, however, you also forget to mention (in that price difference) giving up the 17" GT wheels and tires, bigger front calipers, rear discs and the option to have the autostick tranny. And also, by referring to "Stage 0" on the Limited, I'm assuming you mean just the PCM flash, correct? If so, no. The Limited will match the output of a GT when the PCM is flashed, and Premium fuel is used, because that is the only thing holding the Lite beneath the GT. The only time that the Limited's output will exceed a "Stage 0" GT is with a Stage 1 installed.
2001 PT Turbo - In the process of a major overhaul.. :]
2006 Cobalt SS/SC - Stage 2, 3" Exhaust, Meth and soon to come: Zex 75-shot :]
