I found this using Google:
"The P1793 is unrelated to the shift concerns you are experiencing.
Several hunder burp-free shift mods have been done without a hiccup.
However, to satisfy your tech and the diagnostic flowcharts, I suggest you re-connect the yellow wire to prove that it make no difference.
Have the codes cleared when you connect the yellow wire and start the testing from a stock baseline.
The P1793 will only show up with a professional scanner set to read the transmission control module data.
P0700 is a generic engine code telling the tech to look in the TCM for tranny codes.
Since neither code presents an emission failure, the check engine lamp will not light."
That's from MX-5, who originated the shift mod.
The link is here:
Hello and P1793 error codes - PT Forums - The PT Cruiser Enthusiasts and Owners Resource
