  #13 (permalink)
Old 26 Oct 2009, 08:28 pm
freetobejbp freetobejbp is offline
Default Re: iridium plugs???
Originally Posted by sugees69 View Post
Well, I did'nt know FRAM oil filters are viewed as bad by some. I still plan on giving the FRAM filter a shot. I use Shell oil and gas. I still need help with find good affordable performance wires. Any suggestions?
It all depends on how often you change your oil and filters. I assume you plan to keep that 10k oil filter on through several oil changes i figure at least 3 are 4?
If you change it every 3k are 5k miles a regular duty oil filter is just fine. If you keep a check on the oil you can tell it is getting dirty and starting to break down. I have had my PT for nearly 4 months now i have only put 2000 miles on it the dealer changed the oil before i got it and the oil looked new it already is starting to look bad im getting it changed soon it might make it to 3k but 5k forget it. I plan to use the Castrol GTX high milage 5W-30. Dealer has to use cheap oil.
