Old 26 Oct 2009, 08:54 pm
Chicago_gal Chicago_gal is offline
Default Re: Oh no, multi codes = valve problems? (123, 300, 302, 303, 351, 352, 1193)
It did not drive slowly. I was able to drive on the hwy at speeds of 65+. Just a bit slow pick-up and stuttered start.
I can't say that I trust the mechanic. I only had him do the work in September due to an September. Per the invoice, the work he completed was replaced the oil sender unit, oil pan gasket lower, filter housing gasket. Given the fact that I had to have him replace the oil sending unit this past Saturday, and the input from you and cruiserdad, I don't believe that he is credible.
I have an appt. on Weds morning with another mechanic that received good reviews on yelp. Besides providing the above symptoms and recent repair work completed, should I be suggesting a probable source for the problems? Should I mention that the other mechanic said the two cylinders had no compression?
